immediate crash with csv file and scatter
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
3DRenderTom
latest version of plugin crashes immediately when I try to load any kind of csv file into the scatter node.
This worked with the last version. Also works in standalone.
I'm on windows and the latest build of octane/plugin/c4D.
Thomas
scatter_demo.csv
(235 Bytes) Downloaded 275 times
Ok! Problem is in processing of effectors codes. It's fixed now! Thanks for report!
3DRenderTom
ok now that was fast :-)
thanks,
Thomas
3DRenderTom wrote:ok now that was fast :-)
thanks,
Thomas
Mostly yes. Also giving some good example files that helps much.
VVG
Ahmet, when you add the automatic addition of effectors (if Scatter is selected)? as it is done for Cloner object :D
thanks
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
VVG wrote:Ahmet, when you add the automatic addition of effectors (if Scatter is selected)? as it is done for Cloner object :D
thanks
I need to check how can be done or is it possible for custom objects!
Return to “Bug Reports”
