latest version of plugin crashes immediately when I try to load any kind of csv file into the scatter node.
This worked with the last version. Also works in standalone.
I'm on windows and the latest build of octane/plugin/c4D.
Thomas
immediate crash with csv file and scatter
C. RAM Capacity (i.e. 6 GB)
- 3DRenderTom
- scatter_demo.csv
- (235 Bytes) Downloaded 284 times
Ok! Problem is in processing of effectors codes. It's fixed now! Thanks for report!
Mostly yes. Also giving some good example files that helps much.3DRenderTom wrote:ok now that was fast
thanks,
Thomas
I need to check how can be done or is it possible for custom objects!VVG wrote:Ahmet, when you add the automatic addition of effectors (if Scatter is selected)? as it is done for Cloner object![]()
thanks
