Normal handling in 3.08
Godstrike
I have noticed that while I can dial down the strength of a normal map using the power value in previous versions, with 3.08 and the metallic material at least, dialing down power has negligible effect.
Even on 0, the normal map still affects the material.
Ryzen 5800x at 4.4GHz | 32GB | 1 x 3090 ti | 1 x RTX 2080 ti
3dreamstudios
I have not tested but this would not be great if it can't be addressed. I like being able to overdrive or underdrive normals!
Return to “Lightwave 3D”
