I have noticed that while I can dial down the strength of a normal map using the power value in previous versions, with 3.08 and the metallic material at least, dialing down power has negligible effect.
Even on 0, the normal map still affects the material.
Normal handling in 3.08
- 3dreamstudios
I have not tested but this would not be great if it can't be addressed. I like being able to overdrive or underdrive normals!
