Forester with animation scene upload time
thanulee
Hi, i m testing forester with some high poly trees with wind. I use multicloner for now instead of scatter (will try this later see differences).
Octane renders image very fast but takes quite a while to update each frame. It says "start rendering" and while the render itself takes 8 seconds, this process takes 20.
Is there a way to do this faster?
edit: Just testing scatter and doesnt use hyperwind of forest. Is it possible to support this? thanks
thanulee wrote:edit: Just testing scatter and doesnt use hyperwind of forest. Is it possible to support this? thanks
No!
Octane is not fastest renderer for processing/preparing geometry data for rendering.
thanulee
Ok, so i have to use forester's multicloner when i have wind. Do u happen to know the disadvantages for using multicloner? eg. cannot support huge number of clones as scatter does? Cause these 2 seem similar approaches. thanks
thanulee wrote:Ok, so i have to use forester's multicloner when i have wind. Do u happen to know the disadvantages for using multicloner? eg. cannot support huge number of clones as scatter does? Cause these 2 seem similar approaches. thanks
Yes i know surely! Scatter object has been developed by me for speed. You can put animated objects under scatter but without time offset.
ChrisPettit
For anyone that's interested: I was able to get Forrester wind to work inside the Octane scatter object by caching the wind (under the hyperwind tab in forrester).
www.digitalskye.net
Windows 7 XEON 16 Core, 32GB RAM, Nvidia GTX670
thanulee
ChrisPettit wrote:For anyone that's interested: I was able to get Forrester wind to work inside the Octane scatter object by caching the wind (under the hyperwind tab in forrester).
Awesome! with v4?
Burgess AK
under simulation not Hyperwind
C4D R20
1 x GEFORCE RTX 4090, 64 GB RAM
If you believe in telekinesis, raise my hand
jgardner1284
I just recently completed a project using forrestor and used alot of the wind simluation. Something that worked very well for was to bake out the simulations as alembic files and octane was able to load the geo extremely fast. I would wait until all the wind sims are locked down so you dont need to make any changes.
This worked well for me.
JG
jayroth
How did you deal with motion blur?
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
Is it fast? Oh, yeah!
