3.08 Anisotropy Question
ChrisSuF
Hi there,
how do I use the new Anisotropy Rotation feature in the 3.08 preview?
What kind of image/shader can it put into that slot?
Thank you.
ChrisSuF
Nevermind I found the solution.
You have to use some other shading model that the native Octane BRDF Model. Here's a rundown for those of you interested.
Workflow Anisotropy
Workflow Anisotropy
speltrong
To add to this:
My pattern (256x256px normal map from Google) did not show up until my roughness was at least 0.4, even with the Anisotropy slider set to 1. I also had to use an Image Texture node connected to Rotation and then add a Transform node to that and set my S.X and S.Y to 0.04 to get it to size right.
GIOLETS
Could you please share your material?
I've tried many time but can't see the Anisotropy effect (3.08 test 6.0 - R19)
Luca
i9-10900x, 96GB DDR4, 2xRTX 2080 TI, ASUS X299 SAGE, Windows 10
http://www.visual4d.it
Hi Luca,
as already said by speltrong, you need a good amount of roughness to have a pronounced effect.
Here is a fast example:
anisotrophy_01.zip
(924.4 KiB) Downloaded 349 times
GIOLETS
mmm. interesting, I've placed the same parameters and map on my material and.. don't work.
Note that I've modify an old material made with old Octane version.
If I redo the material starting from zero it work.
Is possible that old materials cannot converted with the new features?
anisotropy_not working.rar
(14.49 KiB) Downloaded 257 times
