OctaneRender™ Standalone 3.07
abstrax
Hi all,
This is the first stable release of 3.07. It's been a while in the making, but the good news is that we are planning to release the first public 3.08 test build in a few days (which has been in development for much longer).
For an overview of all the main changes of 3.07, please check out the new features post. The FBX support isn't fully mature yet and it will take a while until it is, but the rest of the changes should be pretty good by now. We are planning minor 3.07 releases after more bugs have been found and fixed while we are finishing and stabilizing 3.08.
Changes since version 3.07 TEST 7:
  • Reduced visible artifacts when an environment medium is used together with a coherent ratio setting > 0.
  • Fixed crash in Standalone when an output render target linker gets selected.
  • Fixed object handles for placement/scatter nodes which weren't displayed if their parent transformation was placed behind the camera.
  • Fixed crash when an animated scene was loaded and Octane gets closed.
  • Fixed loading of specific 32-bit TIFF images (see viewtopic.php?p=324413#p324413).
  • Lua: Added octane.image.applyGaussianFilter() and octane.image.applyBoxFilter() to blur Lua images. (In case you were wondering: We use it internally for regression testing.)
Downloads for users with a regular license
regular version for Windows (installer)
regular version for Windows (ZIP archive)
regular version for Mac OS X (DMG archive)
regular version for Linux (ZIP archive)
Downloads for users with a subscription license
subscription version for Windows (installer)
subscription version for Windows (ZIP archive)
subscription version for Mac OS X (DMG archive)
subscription version for Linux (ZIP archive)
Demo version downloads
demo version for Windows (installer)
demo version for Windows (ZIP archive)
demo version for Mac OS X (DMG archive)
demo version for Linux (ZIP archive)
Photoshop workflow plugin download
You can download and install the current Photoshop workflow plugin (1.0.5) either via the Adobe Exchange platform or you can download it from the link below and manually install it.
Windows and Mac OS X
Photoshop extension (v1.0.5) (ZXP archive)
Happy rendering,
Your OTOY NZ Team
FrankPooleFloating
Yes!! Thanks M! Now get your butt back in the kitchen and cook us up some 3.08 DBRs! ;)
funk
Thanks guys!
I posted an issue in the last thread. Dirt textures do not show up correctly in the material passes (you get some random noise instead). This doesnt seem to be fixed. I have included some screenshots and an orbx
abstrax
funk wrote:Thanks guys!
Yes, that's a limitation of all version 3 versions. We will fix it in the coming weeks.
funk
abstrax wrote:Yes, that's a limitation of all version 3 versions. We will fix it in the coming weeks.
Thanks abstrax. I thought it might be a bug, since the beauty passes > diffuse filter works. I'm not really 100% sure what the difference is with material passes > diffuse filter (they have the same name)
abstrax
All info passes are rendered using the info channel kernel, while the beauty, light and layer passes are rendered as part of the main rendering. The problem is that for the dirt texture we have to shoot some additional rays, which isn't done in the info channel kernel resulting in garbage. Since version 3 split ray tracing from shading, getting dirt working in all situations is kind of tricky since it needs to be done before the shading step. To make dirt work in the info channel kernel, we have to modify the way how info channels are rendered. It's doable, just hasn't been done yet. Thanks for reminding us ;)
Phantom107
This is great I will test it out in a bit. Thank you for fixing the UI lag in 3.07 test 6, my scenes are getting increasingly procedurally generated so there is a crazy amount of nodes in there and growing steadily. I'll let you guys know how it works out! :D
manalokos
There is an issue when picking a Material group it shows in the node inspector the insides of the material group instead of the group itself.
coilbook
manalokos wrote:There is an issue when picking a Material group it shows in the node inspector the insides of the material group instead of the group itself.
please add a slot for dirt texture to have noise at the edge of a dirt texture and not just gradient transition
abstrax
Thanks for the report. It will be fixed with the next release.
