3.07.t7 Smoke volumes appear to be broken
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
grimm
When I try to use smoke volumes in Blender I can't select OpenVDB as the cache format type as it's missing from the menu. I double checked in version 2.79 and it was there, so I'm assuming that it was removed for some reason in the new 13.1 plugin. Volumes don't work if you can't use OpenVDB. :( Thanks,
Jason
J.C
You need to save the .blend file first to enable OpenVDB cache. This has nothing to do with Octane plugin.
System – Windows 11
grimm
This was with a saved blend file, it was one I had created before. When the file is loaded the cache format is blank. I even tried with a new scene and the only option is the point cache, no OpenVDB option.
J.C
No problem here on OS X version.
smoke cache.jpg (37.25 KiB) Viewed 3111 times
System – Windows 11
grimm
I suspect that they forgot to include the OpenVDB lib with the Linux version of the plugin?
azen
I will confirm within the Linux build, and see what differences in the deployment needed to be accounted for. Apologies for the inconvenience.
DrawFun
Thanks grimm and J.C.
Problem confirmed. It will be fixed in the coming minor version.
grimm
Thanks Azen and DrawFun! :D
Return to “Bug Reports”
