Is it possible to render Normal info channel ? The one that's used for faking geometry detail.
Trying to create flakes normal map, but seems like i will need to use another renderer for that, tried everything i guess, didnt work.
Using 3ds Max.
Tangent Normal ?
C. RAM Capacity (i.e. 6 GB)
- paride4331
Hi Exaco,
you can not have normal map with displacement, with bump texture is tangent texture pass.
Yu can use 3dsMax displace modifier, convert to poly, then baking and render normal map.
Regards
Paride
Regards
Paride
