Problem:.obj from Houdini changed with boolean
lakris
-This is also postet in sidefx Houdini forum-
I am testing Houdini 16 apprentice.
I have created a box and then carved a hole with a tube using boolean.
Then i save/render it to disk, using file node, render to other - geometry.
When i import the .obj into Octane Render, there is no hole.
I have found out that the problem is in Octane Render standalone .(maybe I am missing a setting in OR)
The geometry is not showing correct when I add the mesh(.obj)
If I import it into Blender the mesh is correct, is it a bug or am I doing it wrong?
Thx
Win 10 - 64 bit, Intel Corei7-7800X CPU @ 3.50GHZ, 32 gb ram, 2x Gigabyte RTX 2060 SUPER 8GB, OctaneRender for Blender - The most recent stable build - Houdini indie 18.5.499
Zay
Let us see the OBJ.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 560.94| Modo/Blender/ZBrush/Daz/Poser
lakris
I have uploaded the .obj file
test_1_Objekter_1k.obj
(2.51 KiB) Downloaded 146 times
Zay
Your OBJ is made of Ngons and that is the problem. Convert it to quads or tris.
lakris
Ok, thank you.
I will see if i can change that easily in Houdini
