-This is also postet in sidefx Houdini forum-
I am testing Houdini 16 apprentice.
I have created a box and then carved a hole with a tube using boolean.
Then i save/render it to disk, using file node, render to other - geometry.
When i import the .obj into Octane Render, there is no hole.
I have found out that the problem is in Octane Render standalone .(maybe I am missing a setting in OR)
The geometry is not showing correct when I add the mesh(.obj)
If I import it into Blender the mesh is correct, is it a bug or am I doing it wrong?
Thx
Problem:.obj from Houdini changed with boolean
I have uploaded the .obj file
- test_1_Objekter_1k.obj
- (2.51 KiB) Downloaded 152 times
Win 10 - 64 bit, Intel Corei7-7800X CPU @ 3.50GHZ, 32 gb ram, 2x Gigabyte RTX 2060 SUPER 8GB, OctaneRender for Blender - The most recent stable build - Houdini indie 18.5.499
Ok, thank you.
I will see if i can change that easily in Houdini
