Camera node info
Daniel79
I don't understand where&how it connects the node "camera" to other nodes!
Can someone explain?
I want to save different views but i don't know how...
Thanks a lot
SORRY, MY ENGLISH IS BAD!
2 Xeon quad core E5440_8gb Ram_Nvidia GeForce 2GTX 780ti 3Gb/Nvidia Quadro K2000_Win10 64bit_Octane 3.02_Rhinoceros3D
Jaberwocky
See image attached for ref
in preview config tab create several camera nodes (one is already created at the start)
Connect each up in turn to switch camera views and then manipulate the camera position in each view to get that view right.
After that you can just go to each camera view by connecting each node in turn.
Hope that helps.
Daniel79
Thanks to all...
I have another similar question:
The node "scale" "trasform" "Traslate" how&where i connect to other node??
Ex. Is possible scale the mapping of the texture of normal,diffuse,specular, at the same time?
roeland
You can connect a transform node to a texture generator, like marble or turbulence. Transforming of 2D-textures is not possible at the moment.
Roeland
Daniel79
maybe I explained evil
The scalar function already exists for the single channel of material, I wanted to ask if you can change it at the same time for both the specular channel, bump channel, diffuse channel...
