Out of memory
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
kibbycabbit
Hello,
Softwares & OS:
Mac OS X (Sierra)
Blender 2.78a
OctaneRender for Blender 11.24
OctaneRender Standalone 3.06.4
System:
MacBook Pro with Retina Display mid-2012
GeForce 640MB with 1GB VRAM
16GB RAM
In Blender, I activate Octane's Out of Core with 4GB system memory with 300mb overhead. It doesn't want to render until I decimate all the meshes to total of 340k triangle counts in a scene with considerable amount of textures.
Does that mean I can only render if the meshes can fully fit in VRAM first then use remaining VRAM and OOC for texture files?
System #1: Mac Pro Early 2009, 12GB ECC RAM, Display: GTX 750 Ti 2GB (Maxwell) + CUDA: GTX 980 4GB (Maxwell)
System #2: MacBook Pro /w Retina 15", 16GB RAM, GT 650M 1GB
System #3: PC Windows i9 6 cores, 16GB RAM, RTX 2080 SUPER 8GB
kibbycabbit
Tested with OctaneRender Standalone:
I imported 4 meshes - each at 350k to 600k triangle counts. It can render no problem with 1.6 million triangles and high resolution textures. OOC at 500MB.
mojave
You are correct, out-of-core applies to textures, however your meshes should fit in GPU memory:
https://docs.otoy.com/StandaloneH/Stand ... ttings.htm
If you have any feature requests you can submit them here:
https://render.otoy.com/requests/
kibbycabbit
Ah! Got it. It looks like Blender occupies more VRAM than OctaneRender Standalone. Any tip how I can savage more VRAM space for Octane plugin?
I'm changing GPU Headroom from default 300MB to 600MB in OOC setting in Blender (I have 1GB VRAM). Am I doing it correctly?
Thanks!
J.C
1GB is pretty low especially if you work in Blender not Standalone. Have in mind that system is also taking some memory so yo do not have whole 1GB to use.
You can change headroom to any value if you want. Start with 0 and check if it helps.
You may also try launching Blender render job from terminal without the GUI. This may help saving some memory for Octane.
System – Windows 11
Return to “Bug Reports”
