Micro flickering on glossy surface
OlaHaldor
I'm having trouble rendering simple spheres with an earth graphic on it for some infographics animation.
One sphere is glossy blue, while the other is slightly larger with an image that goes into transparency, so only the landmass is shown, and casts a shadow on the blue sphere.
I've set up the scene with an HDR and a couple of area lights so it looks better.
The render looks fine when I see the progress, but when I play it back, I notice there's some TINY flickering going on, as if there's something obstructing the area lights. 10 frames can be good, then theres every other frame of flickering for 30-40 frames, and then a couple of good frames again, and.. so on..
I've tried adjusting diffuse and glossy depth. I switched off the area lights, and the flickering disappeared, but now the render doesn't look as good. :roll:
Edit:
I increased sampling on the aera lights (default is 1, I increased to 3), don't know how far it's necessary to increase, but it did not have any effect.
Any suggestions on what I may try?
Modo & LightWave 3D | Win 10 x64 | RTX 2080 Ti | Threadripper 2920x | 128GB
What kernel settings are you using? Have you tried the recommended settings in the link in my signature?
OlaHaldor
Hi, I used the Direct Lighting kernel because it rendered faster and the result was close enough to the Path Tracing, and for this animation the tiny difference between the two don't matter.
I will try the Path Tracing again and test with higher Caustic Blur value.
I did a complete re-render last night while away, and I discovered a new issue..
A lot of frames are coming out like this. Flickering like crazy. There is no problem as long as the camera is moving, but once it is still, the flickering like this occurs.
I have the latest GeForce driver and the latest build of Octane as found in the sticky thread.
OlaHaldor
I increased the caustic blur from the default 0.01 to 0.1, no change. Then to 0.3, no change. It still flickers. Then to a full 1.0. Still flickers. :?
May I PM you the scene?
Yes, pls send me the scene.
Return to “Foundry Modo”
