Texture baking for Unity
Moderator: ChrisHekman
Hello, I've been looking for further info on rendering to texture in Unity using Octane. I thought I could use Octane in place of the existing lightmapper but I can't find very much info on how I would do this. Octane doesn't seem show up in Unity's "lighting" menu and the only hint in the PBR Rendertarget I created is the "Render to Texture" slot. I've set my camera to "Baking Camera" and I can see my lightmaps baking in that slot, but I don't know how to apply that "Render to Texture" texture to my scene. Are there any videos or tutorials on this?
Yes this is possible in 3dsMax, here from the docs:mytherapy wrote:Ok, thanks for the quick reply.
Is it possible to bake in 3ds Max using render to texture? Are there any tutorials/videos on that?
https://docs.otoy.com/3DSMaxH/3DSMaxPlu ... Baking.htm
- paride4331
Hi mytherapy,mojave wrote:Yes this is possible in 3dsMax, here from the docs:mytherapy wrote:Ok, thanks for the quick reply.
If you are using material converter (Render Setup > tools > open Octane global preferences ), you can use automatic bake texture tool
and find the baked textures in the assigned folders.
Regards
Paride
Hello, thanks for the responses -
Has there been any news on baking lightmaps directly in Unity using Octane, and does the PBR RenderTarget "baking camera" integrate with Unity lightbaking at all?
Paride4331 - are you talking about this as part of the rendering workflow in 3ds max?If you are using material converter (Render Setup > tools > open Octane global preferences), you can use automatic bake texture tool
