Crash on Macbook Pro every time
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
phil_w
A. Operating System: OSX 10.12.6 (Macbook Pro Retina i7 Mid 2014)
B. Graphics Card(s) model GT 750M
C. RAM Capacity 16GB
D. Nvidia driver version 378.05.05.25f01 Cuda 8.0.90
E. OctaneRender Standalone version, n/a
F. OctaneRender plugin version 3.06.2
G. Host application version, including build number if available C4D R18.057
H. New document - open live viewer window and start live view. Drop a cube into scene. Try to move cube - BANG!
Any ideas? Cheers!
_BugReport.zip
(22.12 KiB) Downloaded 252 times
Did you try on an older version of C4D? It can be a spesific issue to number and osx.
phil_w
I did!
Both previous versions. I was hoping .057 would be the one to fix :-)
I have iMac 5K 27" with Akitio Node eGPU (with a GTX 970 inside) working fine with same version numbers of everything...
Macbook has always done the same.
Is GT 750M too underpowered? Not intending for the Macbook to be a rendering workhorse, but would like to be able to see my Octane scenes ok for quick viewing and roughs...
Thanks!
phil_w
Think I may have found the issue...
If I don't set the Renderer in C4D to Octane I get the crash. If I switch to Octane from Standard before dropping the cube into the scene I don't get the crash.
Windows version doesn't crash in the same situation so must be an OS X quirk....
:D
Return to “Bug Reports”
