Asrock 13 GPU mining MB
pegot
Just saw this on the Asrock site. For bitcoin mining. Could it be used effectively with Octane?
http://www.asrock.com/news/index.us.asp?id=3666
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
Notiusweb
I am looking here now too, It specifically shows a pic of 13 GEForce GTX cards (Nvidia), but only for Linux (???). It shows for Windows a hybrid of 5 Nvidia & 8 AMD...
It has just 2 memory stick slots.
BTW - look at this, by Setup Tip #1!
http://www.asrock.com/microsite/H110ProBTC+/
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
pegot
Looks like it's just Gen2 @ 1x.
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
smicha
At x1 it will be very slow for geometry transfer for Octane works...
I'd use Supermicro x10drx for 11 gpus at x8 :)
Notiusweb
@Pegot -
Are you going to get this!?!!!
Someone has to try it out! :D
@Smicha -
When I saw the headline I was like, whoa - imagining 13 x 8x! :P
Plugs: Enterprise
pegot
Notiusweb wrote:@Pegot -
No. I just built a new computer a few days ago (only holds 4 GPU's though I have three in there now). And my first water cooling system.  But it does use an Asrock MB, which is how I found that 13GPU monstrosity.
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
glimpse
this is a bit risky & slow for OctaneRender.
been to friend a couple of days ago - in few months 24/7 he burned quite a bit of risers/PSU wires, so putting everything together properly is needed, otherwise You might end up having not only melted wire & connectors, but also some issues with burned cards even system.
there are a lot of guys who run setups so they do work, just wanted to mention if You are planing long term investment.
Notiusweb
glimpse wrote:this is a bit risky & slow for OctaneRender.
24/7 - Wow!.....I forgot, there are some of us who are rendering almost non-stop. :o
Those 1x PCI inputs can be inserted incorrectly easily, an d if so possibly bye-bye GPU :?
Plugs: Enterprise
Notiusweb
Nice! Congratulations! BTW - you don't need 13 actual inputs to get 13 GPUs @ 1x. You just need enough PCI lanes (memory from CPU/mobo), and then a GPU splitter (ie an Amfeltec, or 2). A rig with 4 GPU at say 8x will likely expand to 5, 6, or 7 if you split a 8x PCI slot to 3 or 4 1x-connections. Smicha is wielding Ultimate Legendary power with 11 at 8x, the mobo he uses allows that!
Plugs: Enterprise
glimpse
it's not about inserting risers, but also about power draw through powered risers.. - I did see wires with melted molexes, sata even 6pins..- personaly I would avoid such route, unless all You care is how to things as cheap as possible.
Return to “Off Topic Forum”
