Live Viewer keep refreshing
sagun
Hi, I'm having strange refreshing problem with the live viewer. It was working fine before but now even if i select an object, the live viewer restarts the render. Almost every action like mouse hover sends to render and I don't know why ? So far I know the live viewer should only refresh when the settings are changed. :cry: :cry:
sagun
I think the mograph color shader was causing to refresh the live viewer updating.. I replaced the Mix Material which had color shader with normal material and then it stopped refreshing. Is this normal ??? Can we fix it ?
Some objects or setups can cause this. Better to send me a scene for asking a possible fix. But shader effector is not fixable.
DiegoRuizDiaz
Hi, any fix? i have the same problem.
DiegoRuizDiaz wrote:Hi, any fix? i have the same problem.
Please read my answer. You can disable object updates if you wish in case or don't use what's causing this.
