Live Viewer keep refreshing
Hi, I'm having strange refreshing problem with the live viewer. It was working fine before but now even if i select an object, the live viewer restarts the render. Almost every action like mouse hover sends to render and I don't know why ? So far I know the live viewer should only refresh when the settings are changed.
Some objects or setups can cause this. Better to send me a scene for asking a possible fix. But shader effector is not fixable.
Please read my answer. You can disable object updates if you wish in case or don't use what's causing this.DiegoRuizDiaz wrote:Hi, any fix? i have the same problem.
