Working with UDIMs or multi-tile UVS
mikeadamwood
Does Octane C4D work with UDIMs or multi tile? I did notice ID number under Mesh UV projection so I'm hopeful.
I've posted before about creating and texturing varied landscapes and researched UDIMs, I just wanted to know the proper workflow with Octane before I go jumping in. ATM if I want to blend a road with a landscape I'd have to do it all exterally as to use only one displacement, frustrating trying to get a workflow down.
Windows 11 Pro | ASUS Pro WSX80E | AMD Threadripper Pro 5975WX 32-Core | 256GB Micron 8x32GB 3200MHz ECC | 2x PNY RTX6000 ADA
Terryvfx
The Mesh UV ID number doesn't work as far as I understand and Octane for Modo is the only platform that supports UDIMs right now, now I know you will think this is sad and it is so I feel for you brother because I feel the same way too.
kbar
You can work with UDIM workflows in C4D and Octane using 4D Publish: https://www.4dpublish.com/udim-support
It also has direct support for updating textures directly in the Octane Live viewer when painting using the new Paint Brushes...
https://www.4dpublish.com/octane-painting-support/
https://www.4dpublish.com/paint-brushes/
Although there is no video demonstrating the Octane Painting solution, one will be coming soon.
Best Regards,
Kent
mikeadamwood
kbar wrote:You can work with UDIM workflows in C4D and Octane using 4D Publish: https://www.4dpublish.com/udim-support
Best Regards,
Kent
Thanks for the reply. This looks very promising! Very pricey though..
I think in that video found on this page (https://www.4dpublish.com/udim-support) shows support for Octane where instructor states 'the answer is yes this works in Octane', but doesn't use the Octanes image texture node which means it isn't really showcasing compatibility with Octane it's just rendering standard C4D material. The guy in the video is only using color channel which is why it works with a standard Cinema 4D material applied to the model, how would this work with bump, normal, displacement etc..
kbar
mikeadamwood wrote: I think in that video found on this page (https://www.4dpublish.com/udim-support) shows support for Octane where instructor states 'the answer is yes this works in Octane', but doesn't use the Octanes image texture node which means it isn't really showcasing compatibility with Octane it's just rendering standard C4D material. The guy in the video is only using color channel which is why it works with a standard Cinema 4D material applied to the model, how would this work with bump, normal, displacement etc..
The video is demonstrating that you can bring a model into C4D with its UVs in UDIM space (0-1, 1-2, 2-3 etc...). This plugin will then create a new material for each UDIM and automatically hook up all the textures on disk that you have for each UDIM to the appropriate channel in C4D. You can then also view the model in Octane, which already correctly handles the UVs. This plugin currently only sets up Standard C4D materials. Octane Materials will be added in future or sooner if there is more demand for it.
