PLease help with proper grid value
coilbook
Hi we attached a picture of VDB fire 90 mil cells what is the proper max grid value?
How can we calculate. Manual does not explain well because phoenix not have the info about cells
2. Any way to have an option to control smoke and fire independently. Phoenix has volumetric button for final rendering look but it does not work for us
thank you
paride4331
Hi coilbook,
Did you try working on density and volume step length and then adjusting emissions?
Regards
Paride
coilbook
paride4331 wrote:Hi coilbook,
Regards
Paride
yes. But do you know by chance what is the best setting for grid value should be? The proper one
thank you
also there are just so many options to tweak vdbs like emmis scale (from the volume modifier), density, volume step length, power for texture emission, volume ramp texture contributes to brightness, max grid value does too. I wish there was a proper tutorial step by step for proper set up of fire.
paride4331
Hi coilbook,
I am investigating your request, I keep you updated as soon as possible.
Regards
Paride
coilbook
Return to “Autodesk 3Ds Max”
