ImageTexture Over Clones Problem
RJMEngineering
So, I am seeing a problem when overlaying an image texture over the clones and then animating the clones. I have followed the tip Inlifethrill did for his glowing clones tut, and the images are over the clones and working fine (I have a Selection Tag on the Top and one on the Bottom of a cube), the problem is that when I animate them, its like they don't complete the animation. Resending the scene immediately corrects the issue.
I have added ObjectTags to the cloner, the cube but nothing. I had something more complex set up but as I was having this issue, I thought it better to start off a fresh and see.
Any thoughts? Scene file attached too
Rotating Tiles (2).zip
(164.59 KiB) Downloaded 116 times
Ritchie
This happens because plugin ignores the required changes on these meshes. It has a update detection alghorithm and has some controls to avoid every unnecessary updates. Here's a consequense of that.
RJMEngineering
Thank you for replying Ahmet. I thought that is why the object tag is used? Is there not a workaround I can use?
You can add a very small vertex animation to box object as a workaround. I'll check why it's not forcing the updates with "force updates" option.
RJMEngineering
Thank you Ahmet, I will give it a try.
