Unable to activate 3.06.1 plugin for Rhino
reberts2
I am unable to activate 3.6.1.83 plugin for Rhino v5.
I can activate my 3.06.1 standalone license but get a 'Failed to active; no expiry callback...subscription...' message each time.
Thanks!
Rick
Note: reloaded 3.6.5.81 which works fine.
Win 7 64 | GTX260 x 2 | Core i7 860 | 4GB & OSX 10.6 | 8600M GT | Core 2 Duo | 4GB
Hi - can you provide the name of the installer filename you used pls?
reberts2
Yes, current installer for non subscription license used "OctaneRender_3_06_1_win.zip"
Thank you.
Rick
What was the filename of the Rhino plugin installer you used pls?
reberts2
Yes, "OctaneRenderForRhino_3_6_1_83.rhi"
Thank you.
Rick
I cannot find any reason for the error you are getting, but I have re-packaged the installer. Can you pls tell me if this version resolves your problem?
https://render.otoy.com/customerdownloa ... 6_1_83.rhi
reberts2
That one worked fine Paul.
Did not require reactivation after installing either.
Thank you.
Rick
Return to “Rhinoceros 3D”
