OK, so this is very confusing for me, and I've tried figuring out the best way to make this work.
So under the Render Settings, there is a Save section which allows you to save out your image.
However, under Octane Render, there is the Render Passes section where you can save out images with passes.
What if I ONLY ant the Octane Render passes image to be saved and NOT the main render file that C4D wants to save?
How do I do that?
If I uncheck the Save checkbox and add the project to the render queue, it still puts something in the Output File, even if I have nothing saved.
What if I only want one file with the render passes to be exported?
Maybe I'm missing something here...
Jim
Saving out render files confusion.
I've had this issue too, and it was discussed here viewtopic.php?f=30&t=52798 as well.
I haven't found a workaround either, so I generally just let the render settings save area dump out a small jpeg to my dropbox so I can remotely check in on my render progress.
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
