Rasterize node
ReaperTheOne
Is it possible to add rasterization node for displacement? Using bitmaps only isn't cool :(
Goldorak
Working on something like this for 3.07/8
Goldorak wrote:Working on something like this for 3.07/8
Very cool!
Goldorak
Here are some early tests done today in the 3.07 build:
This shows how a render target can be attached to a texture input in 3.07 (via a new built in render job texture node - it doesn't save to file, but feeds back into the node graph). Using a group RJ group node in the current system, you can rasterize all the dependent RT textures (in the right order) before rendering the primary RT, all in one step from the node graph.
Terryvfx
So glad to see the progress, thank you for showing this.
Return to “User requests”
