Local material database and node names on export
wakyak
Hi all!
Two questions:
1. Is a local material database supported within the Blender plugin?
2. When exporting to orbx all my nodes get charming sounding names like "0000000011334EA8", any way of making them retain their original tag?
Cheers /Erik
abreukers
Hi Wakyak, I created a customized localDB, it's just a classic folder (or directory) for my octane materials which were created in BlenderOctane. Provided that the materials are applied to a mesh or something, I find that I can save my octane materials to a .blend file and place that file into the folder, and then if I want to load the same material, I just do a File>append and navigate to the folder where I stored the materials and select the .blend file. The .blend file lets you access the elements in it, and there is one folder within the .blend file that is reserved for the materials. You can then select the material from there.
Marvez
why cant I import a material I setup in Octane standalone save as a ORBX local and then import into blender Octane? ; its something I can do easily with the Rhino plugin
I7 5820K 16MB RAM SSD850PRO GTX 970/780
pegot
Apparently ORBX import is coming to all the plugins:
viewtopic.php?f=32&t=56768#p312265
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
Return to “Blender”
