[URGENT] Immediate Render Failure
jenkfinger
Hi Ahmet,
I cannot seem to render anything without a 'Render Failure!!!' in the live viewer. Scenes that once rendered correctly are also producing a render failure.
I have been using octane render for nearly two years and I haven't had this issue before.
I have attached the render log to see if you have andy ideas how to remedy the issue.
I just cannot render anything which is very frustrating.
I am a commercial user and I need to get work out as soon as possible so your quick feedback would be greatly appreciated.
Many thanks,
Andy.
octane 3.03.3 170501 130037.log
(29.1 KiB) Downloaded 102 times
jenkfinger
...in addition to this, I cannot even run the octane benchmark.
It starts and immediately stops, but with no errors or warnings.
Thanks again,
Andy.
First define which scenes causes the failures. Every scenes or some complex scenes? And did you change somethings on system as nvidia drivers?
jenkfinger
Hi Ahmet,
Thank you for responding so quickly.
I can get the live viewer to render very simple scenes (like a cube and a sphere) but anything more detailed just crashes octane.
I have attached an image of a render that previously worked but does not render now. (The vegetation was added post render)
In an attempt to resolve the issue I downloaded the latest Nvidia driver but this has not made any difference.
I get the error 'Nvidia driver has stopped working and has been recovered successfully'. I have seen this message before but never so frequently.
Andy.
These are not belong to plugin side but trying to help you. First you should try with 3.06. If still happens try with some other drivers. Please send us a scene if it still happens. Also it maybe a hardware problem but not sure.
TonyBoy
I get the same error from Nvidia kernel and always use the newest drivers. I think it's my 960 geforce. It happens less now that I use EVGA Precision XT to restart the fan, The default appears to be 'off'. It has stopped with streaming video and high demands on the card. One time it restarted Windows. If I weren't a pensioner, I would buy a new card.
