Save to ocs/orbx questions?
sjogren
Hi.
I have been trying to export a scene so I could open it in Octane standalone, wanted to try "cloudrendering"!
I noticed some problems, frame rate don't match and if I have the camera locked in Modo then animated focal depth don't match either?
These are not critical because they are easy to change but my main problem is that I have an animated OBJ sequence that don't get transferred and I wonder how to do that? Is it possible, maybe my mistake, or do I need a workaround?
/Niklas
Windows 10 (64-bit) | GeForce GTX 1070 & 970 (416.34) | i7 6850K | 32 GB System Memory
Modo 12.1v2 | Plugin Version: latest beta 4
What release of the plugin are you using pls? And how are you exporting to ocs/orbx?
sjogren
I'm using 3.6.5.118.901 and exporting with the button "save to ocs or orbx format.
One thing that may be important to mention, perhaps crucial is that I'm using EmReader http://www.mootzoid.com/plugin/emreader, it works great in Octane for Modo but maybe not for exporting to standalone!
/Niklas
Hi Niklas - exporting via the button only exports the current frame pls any transform animations on the camera or live meshes. To export vertex animation, use the octane.saveAnimation command.
sjogren
Hi, thanks and sorry if I have missed this!
I did try to search the manual but I don't see anything about this command?
Can I read about this somewhere, probably if I read the forums! :D
Thank you
/Niklas
Hesekiel2517
Hey there,
you can find it in the manual under "Rendering and Exporting Animations"
https://docs.otoy.com/manuals/products/ ... nimations/
Cheers
sjogren
Thank you very much! I had to rearrange some materials for it to match but otherwise it went very well!
thanks again
/Niklas
Return to “Foundry Modo”
