OctaneRender® for Maya® 3.06 (test 4) - 10.18 [OBSOLETE]
BK
This is a TEST version, so be prepared to have some issues. Please do not use it for production.
Plugin's version string consists of two parts - version of Octane core integrated into this release of plugin, and the version of the plugin itself.
Format: <Octane engine version> - <plugin version>
It is enough to mention the <plugin version> part when you report something.
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
For network slave and daemon please download Octane Standalone installer here:
viewtopic.php?f=33&t=60354
  • Lost material bug fixes using alembic and MB on...
  • And minor improvements
Windows
DOWNLOAD
OctaneRender for Maya 10.18
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 10.18 Linux
OSX
Installation:
- Just run the auto installer file.
DOWNLOAD
OctaneRender for Maya - 10.18 OSX
Kind Regards
bk3d
calus
Thanks so much guys :)
(also fixed : Lost material for materials from old scene, and for materials with complex attachement )
Pascal ANDRE
QuinceHungaryKft
Hey Guys,
I know this is still a test version, but we are very excited about the adaptive sampling feature, from which we would benefit a lot. So far we have not dared to test the new plugin. What are the current major issues that still remain with this test version?
Thanks a lot!
calus
QuinceHungaryKft wrote: So far we have not dared to test the new plugin. What are the current major issues that still remain with this test version?
I use 10.18 on my current work and until now it is as stable as last plugin Stable version (9.41).
So there is less issues in 10.18 than in previous stable version as some previous bugs have been fixed.
Pascal ANDRE
renmaxhb
yeah
abeoctane
Hi, I am having a problem with this version, the image files (tiff) dont load, even if I restart maya they dont load, I have to check and uncheck the camera mapped texture box for them to load, If I dont do this the objects renders gray, the scenes were saved with octane 9.41. maya 2016 sp6, .ma format.
abeoctane
Also getting this error again:
Octane engine log:
device 2: data texture 4 was not initialized
device 3: data texture 4 was not initialized
device 0: data texture 4 was not initialized
device 1: data texture 4 was not initialized
And the render hangs.
abeoctane
I tried and since 3.06t3_-_10.8 till Maya® 3.06 (test 4) - 10.18, I am getting the image files error and the objects renders gray, Maya_3.06t3_-_10.7 renders fine.
renmaxhb
REALY TROUBLE: rotation object will change smaller when MB is on :evil:
calus
renmaxhb wrote:REALY TROUBLE: rotation object will change smaller when MB is on :evil:
I guess you are using the symmetric MB direction,
this problem has always been there, this is not really a bug, this is because we are missing MB time sub-sampling in the plugin:
Currently in the plugin, for Motion-blur geometry is only sampled 2 times (= only 1 MB step per frame):
for symmetric, geometry is sampled once before and once after the current time,
so with only 2 samples the geometry at current time is interpolated between the pre-sample and the post-sample.
This is why it shrinks with rotation, symmetric must only be used with at least 3 samples ( = 2 MB steps ),
with only 2 samples we have this:
from geometry pre-sample  to geometry post-sample, vertex interpolation at current time give a shrinked object (red).
So "symmetric" shutter alignment must never be used in Maya,
more than 2 geometry samples per frame is not supported yet in the plugin,
but JimStar is working on it :)
This problem also happen with after and before MB direction for objects with fast non-linear movement, but is more obvious with symmetric.
WORKAROUND
The workaround for this problem is to set your scene at a higher frame-rate for example change from 25 FPS to 250 FPS,
then export animated scene ORBX, in Standalone set the framerate to 25 FPS and that's it:
you can now render the ORBX in Standalone with perfect 10 steps motion-blur.
Pascal ANDRE
