Is there a workaround for this bug?
Did you read my answer?bigskyedit wrote:Im getting the same issue when trying to render a propeller. Did you ever solve this problem?
you need to set "time-sampling" for high values. LV can display it correct when you resend the scene or it will show correct in Picture Viewer. But you need enough time-samplesbigskyedit wrote:sorry, the link doesnt work. So I cant see where it shows the solution.
