Motion blur cropped to square
Grum
I seem to get this issue where if the rotation of an object is too fast I get a bounding box on the motion blur, which also extends far from where it should appear.
Is there a workaround for this bug?
I can't see any images but not a bug i suppose. Have you read this manual and this page until now?
https://docs.otoy.com/#cinema-4d-v3-per ... renderings
bigskyedit
Im getting the same issue when trying to render a propeller. Did you ever solve this problem?
bigskyedit wrote:Im getting the same issue when trying to render a propeller. Did you ever solve this problem?
Did you read my answer?
bigskyedit
sorry, the link doesnt work. So I cant see where it shows the solution.
bigskyedit wrote:sorry, the link doesnt work. So I cant see where it shows the solution.
you need to set "time-sampling" for high values. LV can display it correct when you resend the scene or it will show correct in Picture Viewer. But you need enough time-samples
bigskyedit
thank you so much!
