Export layer mask
milo_dude
Hello people!
I'm trying to export layer masks but but something doing wrong. The mask is so fuzzy. What am i doing wrong?
Thank you!
milo_dude
bepeg4d wrote:Hi milo,
there are a lot of discussions about passes, for example this one:
viewtopic.php?f=30&t=60017
Did you see these video tutorials?
https://inlifethrill.com/octane-cinema- ... er-passes/
Yes, i saw them all, but i didn't found explanation.
Besides there is a some differents betwin v2.xx and v3.xx.
If you don't mind tell me my mistake.
My english is not so good and i could missed some important parts.
:roll:
Hi milo,
have you opened the file with GIMP or PS?
What kind of masks are you using exactly?
What are your kernel and Camera Imager settings?
What are you rendering settings?
milo_dude
Hi!
I'm just opened the file with AE, secause it's animated layer.
I'm using render layer mask.
Here is my render settings:
Hi milo,
1, you should set the Tonemap type to Tonemapped if you worl with info passes
2. Render Layer Masks are not native passes from Octane. They are a feature of plugin and they get extracted from RenderLayer feature of Octane. So you can't see directly in Live Viewer. Plugin runs extra render sessions for every mask to extract the alpha from RenderLayers. But you can test every ID in Live Viewer by activating Render Layer.
3. if you need more sampling, eg. for blurred mask, increase this value.
4. if you need soft infochannels, you need to switch this value to Distributed rays.
In general, it depends from your needs.
milo_dude
Thank you so much for a fast, Informative answer!
It's very helpfull for me!!
You're best)
