I've got a straightforward packaging render with a base material, for basic colour and surface bump, plus a metallic foil on top using a mask in the opacity channel.
This works fine on one part of the model, but isn't working on another part - it only renders the base material. I've been through all the settings and I can't see any mistakes I've made.
Is material stacking just a bit glitchy?
Another question regarding the latest 3.06 build - is it available yet for c4d users with subscriptions like me?
Material Stacking Glitchy
It's limited with some requirements. It's done how much it's possible. Did you read limitations in release topic?
It's still a development build. I made a build over first test SDK but not for second. Because things are needed more tested and takes more time to build/test for every versions. So i didn't want to lost concentration for builds. But yes i'll to make a build for VR versions soon for next test.mitchino wrote:got it working - it was my mistake!
anyway - is the 3.06 update available for subscription users?
