Pool_ my first work with Octane.
Magog
Hi All,
this is my fist work with octane.
Unfortunately the time was short... needed a bit more cooking :roll:
PT, 2h for each image.
i7 970 3.3 GHz | 12Gb Ram | GTx550Ti for display + Gainward GTX580 1.5 Gb and Zotac 590 3 Gb for Octane | Win7 x64 __ Softimage 2011.5
justix
Not bad...just the background picture does not look well proportioned to me, on the 2nd image the window outside looks too big or close..
overall.. a good set :)
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
Very good start, Magog ;)
can you reduce the roughness of the water, now it's seems like gel ;)
DayVids
two things I would have done dif. otherwise very good.
Put a bump or normal map, or something on the floor to stop it from turning to one big reflection where you're supposed to have grout. (perhaps even making the Mesh deform or having dif. materials assigned to that grout if nothing else... time consuming as that would be)
Water isn't usually so flat in its reflective properties, I'd suggest making it a specular material (looks like it's a rough glossy material with some transparency maybe?)
CPU - i7-950 3.06 Ghz, 24GB Ram, Win7 x64, 2 display monitors, GeForce GTX 580 3GB Classified. I'm glad to say I LOVE OCTANE!
Magog
Thanks guys.
A lot of mistakes, I know.. :roll:
..a bit of inexperience with octane, first job, and then the time was really little!!! :(
Magog
Hi DayVids.
thank you very much for your advice!!
radiance
Hey,
Have you tried rendering with pathtracing ? It will give a much better result than directlighting...
Radiance
Magog
Hi Radiance,
all image made by PT.
This is a first preview with DL:
..but is more flat for me with DL.. :roll:
radiant
These are some sweet renders
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
ironelix
Nice render Magog.
I7 2.8 860 -Win 7 64- 8 GB DDR 3 - Gainward GTX 560 Ti 2Giga Phantom
