Hi
I had a problem when rendering with 2 computers.
Main computer (A) : TitanX + Titan
Second (B) : 4 TitanX
octane 3_04_3 - 4.25
I render a scene from 3dsmax with A+B and I have error message (see attachment) in slave deamon
I tried to render from Max with slave deamon with only one card after one, to see if one card have a problem.
I see a problem with the card 3.
When I diseable the 3th card all renders are fine (but slower...ahah)
I tried to render from SA with slave with all cards... no error !!!
Today I render same file from MAx with slave with all cards, but only with TitanX on A, all is fine..
octane 3_05_3 - 4.30
Could it be a problem mixing 2 different cards ?
Is there a problem with max ?
octane 3_05_3 solved some problems ?
net render problem
C. RAM Capacity (i.e. 6 GB)
- paride4331
Hi hhbomb,
have you done these tests with the same file every time?
have you connected a monitor to the third video card is it?
have you tried using a small scene?
Regards
Paride
Regards
Paride
yes
yes, work fine.
yes, with smaller scenes with no texture there was no problem.
yes
yes, work fine.
- paride4331
Hi HHBomb,
could you kindly make this test:
Masters (A):
TITAN connect to monitor but deactive it in Octane
TitanX active in Octane
Slave (B):
4xTitanX active in Octane
remove all monitors
Run your test.
What happen?
Masters (A):
Slave (B):
remove all monitors
Run your test.
What happen?
