Hello,
a. Win10
b. 2xGpus Gtx 1080
c. 64 Gb of Ram
d. nvidia driver 378.66 (latest)
e. Octane 3.05.3
f. 3.05.3 - 4.30 version of 3dsmax plugin
g 3dsmax 2015 (17.0 sp4 commercial)
3dsmax 2015 is crashing everytime i touch everything into the render elements panel.
When i select the pass i need (example ambiant occlusion) under the "render elements" tab, 3dsmax is crashing.
A recover is available in my autoback folder. This created recover is containing the ambiant occlusion pass and 3dsmax is export it well, but when i try to setup it 3dsmax is crashing again.
Everything i do under this tab result to a crash.
It's an elementary part of my workflow, how it's possible ?
You should be pleased to fix that as soon as possible and let me know.
Thanks.
G.
3dsMax Crashes when activate render elements
C. RAM Capacity (i.e. 6 GB)
- paride4331
Hi finkaboutit,
I tried to verify your issue, but all seems to work well.
This issue was in previous releases.
you might try uninstalling and reinstalling Octane render 4.30.
If your issue persists, could you kindly share the scene at the point where it crashes?
Regards
Paride
Regards
Paride
- finkaboutit
Hello,
I tried to re-install but it is not working.
My scene is really simple, it is empty
What can i do ?
Thx.
G.
What can i do ?
Thx.
G.
- paride4331
Hi finkaboutit,
could you kindly share the scene at the point where it crashes and
a couple of screenshots about the process that creates your crash.
Regards
Paride
Regards
Paride
- WhaleHunter
Just leaving an entry for anyone else with this issue.
We had the same issue with Win 10.
Wacom drivers caused the issue for us.
FIX (That worked for us):
https://forums.autodesk.com/t5/3ds-max- ... -p/5652367
