Intersecting Alpha with displacement
joecurrie
I am having an issue with two planes that intersect and create a thin black line in areas the alpha is making invisible. I have tried adjusting ray epsilon and this only occurs when displacement is on. When increasing ray epsilon the gap increases. Attached below some screen grabs with descriptions to illustrate. I know it is very small visibly however these images will be viewed at high res.
Using the latest stable octane plugin and standalone.
Thanks in advanced for any ideas/help.
Ray epsilon increased
close up of gap
close up of gap
Showing thin gap in rendered image
Image showing C4d viewport of intersecting planes
Mac OS X 10.11.4 - Cinema 4D R17 | Geforce GTX980 + 980ti | 32GB
Hi joecurrie,
if you don't want to change the ray epsilon value, then you need to scale down your geometry.
Probably the planes are too big :roll:
joecurrie
Hi Beppe,
Thanks for the reply. The geometry isn't too large approx 100cm I think. The second screen grab in my first post is the ray epsilon value set to the minimum it will go. Is there anything else that can be done?
