I have a few projects that make Ocatane for LW crash / freeze after rendering 99% or so.
Anyone experiencing this? it happens with both Octane 2 and 3 versions.
Crash / Hang-up after rendering 99.9%
using 3.03
network render, but fails also on main workstation.
it seems to happen a lot with scenes that are close to using up Vram and in resolutions of arround 7000-8000 pixels wide X 4000 Vertical.
Out of core creates even more unstable behaviour.
Currently upgrading my 780ti to current 10 series with 8gb vram gpus.
i cant sent files, client confidentiality and they are BIG!
lots of tress and instances....
vram used 1900 / 2200.....
GTX TITAN, TITAN Black, 780Ti
WIN 7/64
I7
Asrock Extreme 3 motherboard
WIN 7/64
I7
Can be a problem related to having very low available VRAM while finishing the rendering, but I'm not sure. If you can attach the log file that you get after a freeze, this could help. You can enable the log file in the plugin options panel.
Anyway, if possible update the plugin to the latest 3.05.3.0 build.
