Hello,
I'm getting a glitch when trying to render big volume files. the one in the attachment is around 200m voxels and is about 1.7 gb, when I go to a later frame with higher voxel count, the artifacts increase and I get error: "attempt to reach null node" or something similar.
when I go to lower voxel count (171m) , the artifacts are gone.
volume primitive render glitch
Can you please attach the scene file to test it here? With enough VRAM, Octane should be able to render this large volume. Perhaps there is a bug in the export code.
Are you working with the latest plugin version?
Sorry, but I'm going to need the scene to reproduce this problem here. In my tests, I can't see these artifacts in the volume rendering. If you can also send me the scene to write the volume bgeo, I could not need the huge volume object file.
