Updating Live viewer takes forever.
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
Yan
Hi!
I have some problems with octane on Mac especially.
Sometimes the live window is stuck with "Updating" message and nothing happens. I need to close C4D and open it again for it to work. I also tried to resend render data and restart new render but it does the same. Is there a fix for this? I'm using the latest version 3.05.3.
The problem is happening on all kinds of situations so it's not related to some particular scene. I got the same this on windows also, but not so often.
Here is the log:
Export materials time= 2128.592 ms
Collect objects time= 19.523 ms
Mesh creation time = 53.586 ms.
Tried to access pin via an invalid ID P_TRANSFORM (243)
Tried to access null node pin
Triangles:53k Disp.triangles:52k Hairs:0 Meshes:7
VRAM used/free/max:2Kb/5.672Gb/6Gb
Out-of-core used:0Kb total used RAM:14.129Gb
Total export Time = 2239.656 ms
could not pick, because rendering hasn't started yet
And here a screenshot: https://www.dropbox.com/s/2vg7vp9i26lsh ... 7.png?dl=0
Thank you!
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, 4x EVGA GTX 1080Ti, Octane-for-C4D 4.x.x, Nvidia 398.82
Can you check with "synch. Geo. Updates=on"? And do you believe that your scene have just 55k triangles? It maybe millio s and takes long time to update?
davidro
Exactly same problem here and can not belive that there is no solution posted.
Hi davidro,
please, go to menu Script/Console and post the Log, thanks.
Return to “Bug Reports”
