Macrorecorder doen't load texture file
mbetke
I I try to record some steps for a script which I need for some automatation and I created a material. The problem is I can't get the texture to load. The recorder doesn't record Octane texture assignment. It worked well in Scanline.
This is what gets recorded:
sceneMaterials["Wood"].diffuse_input_type = 2
sceneMaterials["Wood"].diffuse_tex = RGB_image ()
Now I think I need one more line to the texture path and texture. I hope this is not to special and someone can hep here. :)
PURE3D Visualisierungen
paride4331
Hi Mbetke,
I asked more information to developers, To expose a property of a material, you will want to use the setProperty function (there is also a getProperty function if you need that).
Example: setProperty $.material.diffuse_tex "filename" "[filepath_of_the_texture_file]"
You may want to use "getProperty" and/or "getAttribute" calls to handle checks for attributes
so it would be something like
setProperty $sceneMaterials["Wood"].diffuse_tex "filename" ""c:/dummy.png""
not sure about the '$' sign
they will investigate why this can not be recorded by the macro recorder.
Regards
Paride
mbetke
Thanks. :) Really nice.
mbetke
I wonder if there is list of Mascript commands which are related to Octane. I'm no scripter at all but maybe can doo small stuff on my own.
Return to “Autodesk 3Ds Max”
