half months and were waiting for the same bugs)
1)Wind !!!!
tester! I have already worn out you throw scene
the scene with the wind here! HERE!
five months! Five months I'm waiting for this patch
https://cloud.mail.ru/public/LAyA/fTeZjDmaT VIDEO v3.05 - 4.29 [STABLE] NOT WORK
https://cloud.mail.ru/public/LDbT/BXMMuWojM VIDEO v2.26 .1 [STABLE] WORK
https://cloud.mail.ru/public/EMZc/xwqR72jZ3 scene 3ds max 2014
2) added color AO AO ambient texture (OctaneRender™ Standalone 3.04)
viewtopic.php?f=24&t=56856
We added a new texture pin "AO ambient texture" to the direct lighting kernel node, which allows you to specify an ambient occlusion texture which will then be used for the AO calculation instead of the environment. If the pin is not connected, the environment is used instead (as before). This is useful to get rid of the blue tint on white walls caused by the blue sky (top: no AO ambient texture, bottom: white AO ambient texture):
3) Don't works movable proxy for particles when particles deletes from scene.
Don't works animated bitmap "Syns Frame to Particle Age" with particles.
viewtopic.php?f=81&t=54113
4) camera disappear in the viewport
5) voxelization slow
6) re-design Live BD ( SIGERSHADERS V-Ray Material Presets Pro )
https://www.youtube.com/watch?v=-qc48oeR0Ts
7) the ability to start rendering the animation in the dynamic viewport, as it was in the 1.0-2.0 (Karba) This allows you to do the job, if the standard frame buffer will fail
I am writing to once again list of bugs!!! road map! [SOLVED
- Elvissuperstar007
- Contact:
Last edited by Elvissuperstar007 on Mon Jan 23, 2017 7:00 pm, edited 4 times in total.
Thanks for videos and full scene. This is now in our issue tracking system. bk3d will investigate.Elvissuperstar007 wrote: 1)Wind !!!!
Done, will be in next release.Elvissuperstar007 wrote: 2) added color AO AO ambient texture (OctaneRender™ Standalone 3.04)
This is a limitation of Octane core. Please post feature request here:Elvissuperstar007 wrote: 3) Don't works movable proxy for particles when particles deletes from scene.
viewforum.php?f=23
Fixed. Will be in next release.Elvissuperstar007 wrote: 4) camera disappear in the viewport
Christophe has already improved the scene evaluation time, and there are more optimisations to come. We are currently prioritising bugs.Elvissuperstar007 wrote: 5) voxelization slow
This is already in our issue tracking system. We will work on it.Elvissuperstar007 wrote: 6) re-design Live BD ( SIGERSHADERS V-Ray Material Presets Pro )
We will see if we can do something similar.Elvissuperstar007 wrote: 7) the ability to start rendering the animation in the dynamic viewport, as it was in the 1.0-2.0 (Karba) This allows you to do the job, if the standard frame buffer will fail
- paride4331
Hi Elvissuperstar007,
I tried your scene (wind) and it does not works in 2.26 and 4.29 too.
Could you kindly try the attached scene?
Does It works for you?
In your opinion, where is the difference between this and your?
Regards
Paride
Regards
Paride
- Attachments
- wind.zip
- (372.82 KiB) Downloaded 227 times
bk3d spent a whole day on the Wind issue that you have reported and meticulously investigated it.
The wind animation does not work even using the default renderer. He even uninstalled Octane.
It has to be a bug in SpeedTree.
Because if bk3d set static camera then it works in default renderer AND Octane.
Please report a bug to SpeedTree.
- Elvissuperstar007
- Contact:
I recorded a new video, take stillparide4331 wrote:Hi Elvissuperstar007,
Regards
Paride
https://cloud.mail.ru/public/4Ese/e9xsV5sxD
- Elvissuperstar007
- Contact:
I recorded a new video, take stillhaze wrote:bk3d spent a whole day on the Wind issue that you have reported and meticulously investigated it.
