I am writing to once again list of bugs!!! road map! [SOLVED
Elvissuperstar007
half months and were waiting for the same bugs)
1)Wind !!!!
tester! I have already worn out you throw scene
the scene with the wind here! HERE!
five months! Five months I'm waiting for this patch
https://cloud.mail.ru/public/LAyA/fTeZjDmaT VIDEO v3.05 - 4.29 [STABLE] NOT WORK
https://cloud.mail.ru/public/LDbT/BXMMuWojM VIDEO v2.26 .1 [STABLE] WORK
https://cloud.mail.ru/public/EMZc/xwqR72jZ3 scene 3ds max 2014
2) added color AO AO ambient texture (OctaneRender™ Standalone 3.04)
viewtopic.php?f=24&t=56856
We added a new texture pin "AO ambient texture" to the direct lighting kernel node, which allows you to specify an ambient occlusion texture which will then be used for the AO calculation instead of the environment. If the pin is not connected, the environment is used instead (as before). This is useful to get rid of the blue tint on white walls caused by the blue sky (top: no AO ambient texture, bottom: white AO ambient texture):
3) Don't works movable proxy for particles when particles deletes from scene.
Don't works animated bitmap "Syns Frame to Particle Age" with particles.
viewtopic.php?f=81&t=54113
4) camera disappear in the viewport
5) voxelization slow
6) re-design Live BD ( SIGERSHADERS V-Ray Material Presets Pro )
https://www.youtube.com/watch?v=-qc48oeR0Ts
7) the ability to start rendering the animation in the dynamic viewport, as it was in the 1.0-2.0 (Karba) This allows you to do the job, if the standard frame buffer will fail
Last edited by Elvissuperstar007 on Mon Jan 23, 2017 7:00 pm, edited 4 times in total.
Goldisart
octane render live their lives
maybe it's right - - - they have their own goals and tasks - - - but we the users that does not help
haze
Elvissuperstar007 wrote: 1)Wind !!!!
Thanks for videos and full scene. This is now in our issue tracking system. bk3d will investigate.
Elvissuperstar007 wrote: 2) added color AO AO ambient texture (OctaneRender™ Standalone 3.04)
Done, will be in next release.
Elvissuperstar007 wrote: 3) Don't works movable proxy for particles when particles deletes from scene.
This is a limitation of Octane core. Please post feature request here:
viewforum.php?f=23
Elvissuperstar007 wrote: 4) camera disappear in the viewport
Fixed. Will be in next release.
Elvissuperstar007 wrote: 5) voxelization slow
Christophe has already improved the scene evaluation time, and there are more optimisations to come. We are currently prioritising bugs.
Elvissuperstar007 wrote: 6) re-design Live BD ( SIGERSHADERS V-Ray Material Presets Pro )
This is already in our issue tracking system. We will work on it.
Elvissuperstar007 wrote: 7) the ability to start rendering the animation in the dynamic viewport, as it was in the 1.0-2.0 (Karba) This allows you to do the job, if the standard frame buffer will fail
We will see if we can do something similar.
paride4331
Hi Elvissuperstar007,
I tried your scene (wind) and it does not works in 2.26 and 4.29 too.
Could you kindly try the attached scene?
Does It works for you?
In your opinion, where is the difference between this and your?
wind.zip
(372.82 KiB) Downloaded 224 times
haze
bk3d spent a whole day on the Wind issue that you have reported and meticulously investigated it.
The wind animation does not work even using the default renderer. He even uninstalled Octane.
It has to be a bug in SpeedTree.
Because if bk3d set static camera then it works in default renderer AND Octane.
Please report a bug to SpeedTree.
Elvissuperstar007
paride4331 wrote:Hi Elvissuperstar007,
I recorded a new video, take still
https://cloud.mail.ru/public/4Ese/e9xsV5sxD
Elvissuperstar007
haze wrote:bk3d spent a whole day on the Wind issue that you have reported and meticulously investigated it.
Goldisart
UPS
ThaRaven
Renders Fine in 4.29 when i check "movable Proxy" on my Tree
Win 7 64 | Geforce GTX780 |Dual X5667 Xeon | 40GB | MAX 2016 |
Return to “Autodesk 3Ds Max”
