Adding Credits?
- mitch.scott
How do you go about adding credits to your account? I did some tests using my trial credits, but now that those have run out how do I add more? I have linked a CC but saw no way of actually adding them.
- mitch.scott
Well I found out how to add credits. Now my issue is speed. The frames are taking longer than they would on my computer (I have 2x gtx 1070). It is a hefty orbx file at 1.8 gigs but there can't be more than one node/computer rendering it.
- Rikk The Gaijin
ORC only makes sense for animations, because different nodes will render different frames simultaneously.mitch.scott wrote:Well I found out how to add credits. Now my issue is speed. The frames are taking longer than they would on my computer (I have 2x gtx 1070). It is a hefty orbx file at 1.8 gigs but there can't be more than one node/computer rendering it.
If you are rendering a still image, you are better off with your own hardware, unless you are outputting at a massive resolution.
here is a lua script to animate still frames in separated tiles:
viewtopic.php?f=73&t=59099
- RJKohler44
How did you add credits?mitch.scott wrote:Well I found out how to add credits. Now my issue is speed. The frames are taking longer than they would on my computer (I have 2x gtx 1070). It is a hefty orbx file at 1.8 gigs but there can't be more than one node/computer rendering it.
