Adding Credits?
Forums: Adding Credits?
Discussion forum for OctaneRender Cloud
Adding Credits?
Postby mitch.scott » Sat Jan 21, 2017 1:53 am
mitch.scott Sat Jan 21, 2017 1:53 am
How do you go about adding credits to your account? I did some tests using my trial credits, but now that those have run out how do I add more? I have linked a CC but saw no way of actually adding them.
mitch.scott
Re: Adding Credits?
Postby mitch.scott » Mon Jan 23, 2017 6:05 am
mitch.scott Mon Jan 23, 2017 6:05 am
Well I found out how to add credits. Now my issue is speed. The frames are taking longer than they would on my computer (I have 2x gtx 1070). It is a hefty orbx file at 1.8 gigs but there can't be more than one node/computer rendering it.
mitch.scott
Re: Adding Credits?
Postby Rikk The Gaijin » Fri Feb 17, 2017 8:43 am
Rikk The Gaijin Fri Feb 17, 2017 8:43 am
mitch.scott wrote:Well I found out how to add credits. Now my issue is speed. The frames are taking longer than they would on my computer (I have 2x gtx 1070). It is a hefty orbx file at 1.8 gigs but there can't be more than one node/computer rendering it.
ORC only makes sense for animations, because different nodes will render different frames simultaneously.
If you are rendering a still image, you are better off with your own hardware, unless you are outputting at a massive resolution.
Rikk The Gaijin
Re: Adding Credits?
Postby bepeg4d » Fri Feb 17, 2017 2:35 pm
bepeg4d Fri Feb 17, 2017 2:35 pm
here is a lua script to animate still frames in separated tiles:
viewtopic.php?f=73&t=59099
ciao beppe
Re: Adding Credits?
Postby RJKohler44 » Fri Feb 17, 2017 2:55 pm
RJKohler44 Fri Feb 17, 2017 2:55 pm
How did you add credits?
RJKohler44
Return to OctaneRender Cloud
Tue Jul 14, 2020 8:17 am [ UTC ]
