OctaneRender® for Maya® 3.05.3 - 9.23 [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2015, 2016, 2016.5 and 2017 64-bit on Linux operating systems, and 2016, 2016.5 and 2017 64-bit on OSX operating systems (including and above 10.9).
To run OctaneRender™ for Maya® plugin, you need to also have an OctaneRender™ Standalone license.
You can not purchase and use only the Maya plugin and use it without also owning an OctaneRender™ Standalone license.
viewtopic.php?f=24&t=58640
Windows
DOWNLOAD
OctaneRender for Maya 9.23
OctaneRender for Maya DEMO 9.23
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 9.23 Linux
OctaneRender for Maya DEMO - 9.23 Linux
OSX
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 9.23 OSX
OctaneRender for Maya DEMO - 9.23 OSX
calus
JimStar wrote:
  • Relaxed the requirement of unique transform names for Maya versions including and later than 2016.
Thanks ! :)
I guess this option in the render setting UI can be removed ?
JimStar wrote:
  • Fixed the region rendering bug.
[/list]
one more thing:
When "pick focus region" and "autofocus" are enabled, as by default,
drawing a marquee region in IPR render-view restarts the render from zero again.
In my opinion this should not happen in this case, as the marquee region tool is supposed to have no effect with this configuration,
so this is confusing, and also can be very annoying as it's easy to draw a region by accident.
Pascal ANDRE
itsallgoode9
awesome, thanks for the render region fix, being able to use render region is a a lifesaver for me right now.
