OctaneRender™ Standalone 3.05.3
abstrax
Hi all,
This is another bug-fix release to sort out a few issues that got noticed with the last version. In the next 1-2 weeks we plan to release a test build of 3.06 with new features and also some restructuring to address problems with CUDA 7.5 and 8.
Changes since version 3.05.2:
Downloads for users with a regular license
regular version for Windows (installer)
regular version for Windows (ZIP archive)
regular version for Mac OS X (DMG image)
regular version for Linux (ZIP archive)
Downloads for users with a subscription license
subscription version for Windows (installer)
subscription version for Windows (ZIP archive)
subscription version for Mac OS X (DMG image)
subscription version for Linux (ZIP archive)
Demo version downloads
demo version for Windows (installer)
demo version for Windows (ZIP archive)
demo version for Mac OS X (DMG image)
demo version for Linux (ZIP archive)
Photoshop workflow plugin download
You can download and install the plugin either via the Adobe Exchange platform or you can download it from the link below and manually install it.
Windows and Mac OS X
Photoshop extension (v1.0.3) (ZXP archive)
Happy rendering,
Your OTOY NZ Team
Jolbertoquini
Hi Guys,
This is Great, thanks a lot for the update.
I have a quick question, I always was wondering if would be possible to have a " shadow catcher" with a glossy shader so we could reflected the object at same time to have the shadows?
I know we could use render layer but for a quick result without comp then on post.
Best,
JO
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
J.C
abstrax wrote: [*] Fixed the incorrect display of the viewport background image (see viewtopic.php?p=300824#p300824).
Thanks for the update! This is working now properly.
System – Windows 11
calus
didn't get the answer in previous release Topic so posting again here
abstrax wrote: the matte is only evaluate during path bounces and not during the direct light calculation, i.e. it doesn't throw a shadow and won't shade the emitter. That's currently a limitation of the kernel split we did for version 3.
@Abstrax,
from your words this is not obvious that this V3 limitation is the reason of Shadow catcher not casting shadow, since this only happen when "alpha shadows" is enabled in kernel,
and in V2, Shadow catcher always cast shadow even when "alpha shadows" is enabled in kernel.
Can you confirm this ?
ShadowCatcherAlphaShadows.orbx
Pascal ANDRE
enricocerica
Just play around with last version of Octane for Blender with some existing scenes and noticed several issues:
The available videos cards are not available, I couldn't activate or deactivate them, Octane GPUs is empty.
Sometimes, pressing F12 crashes but often nothing is happening, it stays on Render target-evaluation on server or displays Waiting for image and then stop the rendering without displaying anything.
When by chance the available cards could be chosen in the interface, if I activate the 4 cards I have, it seems that only one is used.
Again when by chance the 4 cards work together (can't explain why it works sometimes), I can see it by the fact that the samples per second increase when I add a card, the rendering speed is around 3-4 times slower than with the standalone version using the same scene.
http://www.myline.be
Saramary
enricocerica wrote:Hi,
... or displays Waiting for image and then stop the rendering without displaying anything.
Have you checked System Console? I think you could be out of GPU memory. Anyway worth checking console for messages. ;)
Win 8.1 x64, i7-4930K 64GB, 2 x GTX-690
enricocerica
Ok, I made some more tests and discovered a strange behavior.
I start the Octane Server then start BlenderOctane, Octane GPUs in the render panel is empty as if my cards weren't recognized, I press F12 to start the rendering and got the problem and indeed a memory problem is reported on one card in the console, the one with only 3Gb, though the scene worked fine with the previous versions.
I stop BlenderOctane and restart it, Octane GPUs in the render panel is fulfilled with my cards and this seems to be a constant behavior, I mean the first time you start BlenderOctane after starting the server, no GPU is recognized but it's fine the second time you start BlenderOctane , I press F12 and got the same issue.
I deactivate the problematic card, the one with only 3Gb and press F12 to start rendering with the GTX1070, the rendering is working fine and I got the image.
I stop the rendering, add the card with 3Gb and it works fine, no more memory problem.
I could reproduce this behavior several times.
Start Octane Server, start Octane 4 Blender, load the scene, F12, the render starts but got this in the console :
Octane: ERROR. Server log:
Failed devices:
GeForce GTX 780(device 3), error message: "CUDA error 2 on device 3: out of memory -> failed to allocate device array"
Last Octane engine log entries:
device 3: the device failed immediately after the recovery -> giving up and switching the device into error state
Stop Octane 4 Blender, restart it, load the scene, F12, render stop with no image and got this in the console :
Failed devices:
GeForce GTX 580(device 2), error message: "CUDA error 2 on device 2: out of memory -> failed to allocate device array"
As said if I first start the rendering with the GTX1070, stop it, add one or more cards, restart the rendering, I get no error.
mib2berlin
Hi enricocerica, I cant reproduce missing cards at start with latest Blender for Octane on Linux.
Did not check memory error yet.
May you post in Blender Bug Report thread too, JimStar reply quiet fast and if he can reproduce error he fix fast too last few month.
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
enricocerica
mib2berlin wrote:Hi enricocerica, I cant reproduce missing cards at start with latest Blender for Octane on Linux.
Cheers, mib
I completed my last post with the information.
Elvissuperstar007
add function mirror texture (X.Y)
