Issue With mirrored Uv's
omardex
Greetings, I'm having this issue with a model and mirrored Uv's that the tangent and the normal map appears inverted.
tried with bump map same error, standard c4d render doesn't behave this way
Can't post the scene but I'll posting as much screenshots as possible.
Any suggestions or workarounds?
Tech stuff: Octane 3.05-test 4.1 ; cinema 4d r18.028 ; Video card: Gf 980Ti ; textures size 8k (all those render good and fast except normal maps in the mirrored Uv's)
Quick test for the textures on marmoset 3
c4d quick test with normal and diffuse texture
Octane Live viewer Tangent pass
Octane Live Viewer render
Omar Tavera
Awesome Generalist
omardex.artstation.com
Octane render for c4d but moving more toward standalone with one 980ti
Hi omardex,
it's a limitation of OctaneRender, not of the plugin.
Basically you have to create a second material with the inverted option active in the normal map node and assign it to the flipped part.
Se this other discussion:
viewtopic.php?f=9&t=52434&p=263215&hili ... vs#p263215
omardex
Thanks Beppe, Big help!!
Omar Tavera
Awesome Generalist
