OctaneRender® for Maya® 3.05t4 - 9.12 [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2015, 2016, 2016.5 and 2017 64-bit on MS Windows operating systems, 2017 64-bit on Linux operating systems, and 2017 64-bit on OSX operating systems (including and above 10.9).
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of Octan eRender™ Standalone on your machine.
viewtopic.php?f=33&t=58058
  • New 3.05 test 4 engine integrated.
  • Improvements in render passes handling.
  • Fixed render crash while some specific passes enabled.
  • Added "Merge unwelded vertices" attribute to mesh objects (affects non-global meshes only).
  • Fixed hair rendering bug.
  • Minor fixes and improvements...
Windows
DOWNLOAD
OctaneRender for Maya 3.05t4 - 9.12
Linux
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - 9.12 Linux
OSX
Installation:
- Just run the autoinstaller file.
DOWNLOAD
OctaneRender for Maya - 9.12 OSX
calus
JimStar wrote: [*] Fixed hair rendering bug.
Thanks a lot for the fix !
But a new bug have been introduced in this release:
- when exporting animated scene as ORBX/alembic, the OpenSudiv level is not exported.
This bug doesn't happen with non alembic ORBX export.
Also another recent bug, but don't know since which exact release:
- LayerID is broken, whatever ID is assigned to an object, it always have ID 1.
So basically we can't use octane render layer anymore.
Pascal ANDRE
