Morphs causing smoothing issues.
electric_eric
I have a glossy object that I'm deforming with endomorphs. Everything looks smooth in open GL and both surface editor and gloss nodes have smoothing checked.
The issue I'm having is that when I apply the morph in morph mixer the smoothing no longer works and i get a faceted look to my render.
I'm not using any bump or normal maps.
Is this a known issue or am I doing something wrong?
Thanks.
Intel i7 6700k - 64gb Ram - 6 x 980ti
juanjgon
Do you have this problem in the IPR or in the final rendering? If you want to send me a sample scene with this issue, I could test it here.
Return to “Lightwave 3D”
